Disponibile una nuova versione di driver Omega basata sui Catalyst 5.12 rilasciati ieri da ATi Technologies. Di seguito, link per il download e modifiche:
Download:
What's New in Omega Drivers?
v2.6.87
[*] Based on the Catalyst 5.12 Official drivers.
[+] Added support for 2560x1600 and 1600x1024 resolutions.
Note:
I did a lot of testing to make sure the new installer works as intended, but it still may have some bugs, so if you find ANY problems with the new installer/uninstaller, please mail me and let me know.
Known Issues:
1) Some of the settings for both D3D & OGL will not be synchronized between ATT and the normal ATI CP, you must only use one of them to make changes, the best option is to use ATT since the ATI CP does not support changes to AI and in order to use the advanced D3D/OGL features. Changes made in ATT will work on games and such but the changes will not be reflected in the normal ATI CP since ATI stores the registry values that the CP reads separate from the actual values in the registry.
2) If ATT refuses to run because your card is "Not Supported", edit the "atitray.ini" located in the Omega Drivers>ATT installation folder and change "opt_disable_ovr=0" to "opt_disable_ovr=1", this will disable Overclocking, but the rest of ATT can be used normally.
Important Info:
Since these drivers include a non-standard version of ATT, I would recommend that if you have any previous version of ATT installed, please uninstall it before installing these drivers, not doing so may cause unknown problems.
